TwinTurbo.NET: Nissan 300ZX forum - While I would like to redo it the problem is
Subject While I would like to redo it the problem is
Posted by ZXRider on April 02, 2010 at 2:46 AM
  This message has been viewed 77 times.
In Reply To Personally, being a touch OCD, I'd redo it posted by Broke_as_**** on April 02, 2010 at 01:50 AM
Message I don't see any way I could position the thermostat housing in the spot it needs to be and attach the pipe at the same time without smearing the RTV on both surfaces. It took some steady maneuvering to get the thermostat housing to sit correctly. Have you ever done this job on your engine? Maybe you could give me some tips on how to do it.
I know I cannot install them together as one unit. Because of the shape of the housing, it cannot be installed going downward, hence it needs to be installed from the front of the engine, and if the pipe is attached to it the back end of the pipe will interfere and won't let the piece go in.
My brand new freeze/core plugs were leaking and I ended up pulling the engine just to replace those, now it looks like this connection itself was the culprit. What I do not understand is that I originally never separated the two pieces and installed it as one piece, yet it leaked. I have gotten really paranoid about this and do not want to have any leaks again when the engine is installed, that's why I am being extremely cautious about smearing the RTV.
Buy Zama Posters Here
I have nightmares about that happening...I'd be the poor bastard you'd hear about on the news that gets killed by a softball-size chunk while spreading out my body over the hood and screaming "Nooo!" (Having a conversation about hail damage) - BradZ (FL) on March 25, 2005 at 9:56 PM
Tell your friend that you could take a dump, light it on fire and that would be hotter shit than his car. Probes suck, that's just all there is to it. - 300ZXpert (someday) on April 04, 2005 at 11:35 PM
P.S. You REALLY are on here at ALL hours! And I thought I was bad! :) - zmenon on August 16, 2005 at 3:06 AM
LOL...2+2 drivers should grow mullets..."Business in the front...party in the back" ;) - BradZ (FL) on November 29, 2005 at 4:45 PM
